New engine
miller1098
Carno,Welsh Wales
M
After a lot of looking at options and many phone calls I’ve managed to get hold of an engine for the roadster.The initial plan was to rebuild my old engine and to that end I’d bought myself a crank and a set of pistons and rods all second hand but serviceable,the crank would need a slight regrind but I had spoken to a few people and a small grind on a m crank is no problem but even with using my parts the cost of a full strip down and rebuild with a new oil pump and vanos service and other various seals gaskets and sundries would be quite a few k that with me taking the engine out and putting it back in. In this case the engine would be as good as a new one but my pocket couldn’t take it. Anyway I’ve got hold of a 60k engine s50b32 that will plug and play . I’ve got a guy who will put new shells and bolts in the engine clean and check the oil pump do a spring upgrade oil antifreeze and filters take out my old engine and put the replacement in for £950 2 days work ,hopefully the end of April
Be good to strip the old engine apart so we can see exactly what happened, obviously we know from experience by the noises but others wont.
PHILIP BAXTER
Cardiff
Z3 3.0i Roadster
That's great news Hugh. Can't wait to the roadster burning up the roads of Mid Wales. :thumbsup:
Mario
Hey I am pretty interested in the outcome of this, how much was the replacement engine please? Also curious as to what sort of spring he´s putting on those pumps, because I also need to do mine, if you can find from him what spring it is or see if he would sell me one that would be great.
What are you doing with the old engine and rotating assembly?
Cheers
miller1098
Carno,Welsh Wales
M
Cheers
Yes no problem I’ll ask ,I’m going to sell the old engine with the replacement crank and pistons and rods as a package for someone who fancies a go at engine building. I’m more of a driver than a builder and my driving has left a lot to be desired lately lol.
137699
Hampshire
M Coupe 3.2 S50
Good luck Millers - having been through exactly this last year (same cause but I paid for someone else to fit the replacement) I know the pain & costs involved... but mine is running SOOOO well now - have to say it all worked out well in the end!
ktnez99
West Midlands
Z3 2.8L
What do you do with the mileage on the clock being different due to the engine change?
You can make a note of it but there is no requirement to do so. With an ///M car it would make sense, especially as it’s being documented on here.
