New 2.8 Z3, exhaust smoking…
Robking
Hi all,
I’ve recently bought a 1997 2.8 with around 78000 miles. I’ve wanted one since I started driving 5 years ago. So far it’s been more of a project than I had hoped…to sum up the car, on the way home I felt big vibrations on lift on the M25. When I looked, the rear left wheel was only held on with a few threads….
anyway, I have a few easier jobs on the go like diff oil/gearbox oil etc, I am an engine tech in F1 so am decent mechanically however I struggle to diagnose some of the cars quirks.
Most recently I have had some smoke on start up which I put down to early mornings in cold weather. Today the car really smelt on start up, more of oil than fuel. I have attached photos of the exhaust at start up and 10 minutes later once the fluid inside had burnt off. You can see a thick black smudge At the back of the pipe.
i have no cooling issues or coolant loss so hope it’s not a head gasket issue. I have a small leak from the rocker cover but not enough to noticeably lose oil.
has anyone had a head gasket blow or similar issue?
Many thanks,
Rob
:welcome: to the Forum from West Cumbria. If the smoke is on start-up and occasionally when you lift off the throttle it's most likely valve guide seals. If it was constant you'd have a bigger issue.
Robking
Thanks Andy. It’s at least not the head gasket I did a few tests for that this morning. Cheers mate
Ianmc
New Forest
Z3 (M44)
If the car has been used "sparingly" (loose wheel might so indicate) and fluids are OK, could be in need of a good run? :thumbsup:
:welcome: Give it an Italian tune up then see how it behaves.
By the looks of those tail pipes it ain’t burning much oil. Some video might be more useful to help assess it.
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
Andyboy
SHEFFIELD
It's normal. Cold start up steam - BMW exhausts are double skinned and take ages to clear out. M52's have pretty strong cold start fuelling so a sooty exhaust tailpipe is nothing unusual.
Chances are you still have a Nikasil engine and these really dislike short trips and being fired up and shut off again before being fully warmed up.
