Need to slam her now
DirtyDog
Aylesbury
I know this has been covered before, but I cant find it.....
Just had my 17" wheels refurbished.
Now spaced out with 20 mm spacers on the rear, and I have a set of 12 mm spacers coming for the front.
From the pictures as you can see, there is a massive gap which is made worse visually by spacing the wheels out.
What is the consensus for lowering springs from the usual 3 manufacturers people .
From the top of my head these are the ones I remember being used/discussed.
Price as always has a factor, but there is not amassive difference in price here.
http://www.eurocarparts.com/ecp/c/B...96fd0d463818bdb6df82df7f03716d6c776a61&000559
https://www.autodoc.co.uk/eibach/19...bBoOmEdHsRX50XE5_0Wd9SqRiLB3ro09IORoCC7Pw_wcB
https://www.spring-loaded.co.uk/pro...g~Kit~BMW~Z3~E37~4Cyl~1.8/1.9~1996-2003~-30mm
Thank you for any information.
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Eibach are very good, that would be my choice albeit H&R are also a reputable name just have no experience with them.
5harp3y
I've got 30mm eibachs and bilstein b4 shocks
I love the stance and the drive, so compliant but nicely sporty
5harp3y
Springs cost £130 I think
Shocks £150 ish
Plus new top mounts etc etc
So probably £350 all in to do it properly
Davyhoogy
Sunderland
'98 2.8 z3
I've got those apex. And I would advise going for eibachs. They are very low. All speed bumps are a no go!
DirtyDog
Aylesbury
Shocks £150 ish
If you know where to get them for £130 mate let me know.
The cheapest I found d them was that link k I put up.
I take it I don't need to change the shocks and top mount at this stage if they are ok .
£350 is a bit past my steath buy limit:whistle:
Devon Z
Brixham, Devon
99 2.0 Individual
I thought the Zed ran too high and ordered Eibach (at the time they manufactured Shnitzer springs for BMW) fitted them them when she was two weeks old and had her tracked at the dealer to Shnitzer settings. She sits and rides perfect for me, never really found a speed that was too tall but if you go over too quick coming down they can catch the front of the chassis rails! mine don't have much texture to the underbody mastic:meh:
Mnbrennan
Aylesbury
BMW M Coupe / 2.8 roadster
Watching this keenly as I'd like to do the same
5harp3y
That's what I paid from eBay.de but looks like they are more expensive now
DirtyDog
Aylesbury
I think you should be the Aylesbury Guinea Pig and try it first Martin.
You have no kids ( apart from Stacey :whistle:) so lots of money to change if you go wrong;)
Mnbrennan
Aylesbury
Only if you give me a hand!
https://www.spring-loaded.co.uk/proddetail.php?prod=H&R~~Spring~Kit~BMW~Z3~E37~4Cyl~1.8/1.9~1996-2003~-30mm
Popped Bilstein B12 Pro Suspension kit on mine from Venom Motorsports. Eibach springs were the springs that came with it. 30mm drop all round. Looks and runs great :D
Second what most of you are saying, I've lost count the amount of lowering springs I've fitted now and feel the Eibachs are the best value for money.
If you doing it on a budget you can fit on your existing shocks or replace them with OEM shocks. If your pockets are a little deeper Bilsteins are amazing.
I have fitted eibachs to Pauls, Gaz's and mine but fitted H&R to the Wifes z3. The H&R sit lower than the Eibach's.
If you plan to fit them at home careful with the front springs, I couldn't get enough compression with spring clamps because the springs nearly double in length once its relaxed.
