Ok you clever lot I have a few (ahem) codes. Some advice would be greatly appreciated and sorry its such a long post.
122 Temp Sensor Oil (reads 154.98) Assume this is just a replacement item?
227 Lambda Control Bank 1
228 Lambda Control Bank 2
191 Lambda Probe heating downstream sensor 2
202 Lambda Regulating limit bank 1
203 Lambda regulating limit bank 2
Running the car showed the following using INPA on Lambda Probe
Before Cat bank 1 0
Before Cat bank 2 0
TV probe heating before bank 1 99.31
TV probe after bank 1 99.31
TV probe heating before bank 2 99.31
TV probe after bank 2 99.31
Lambda probe after cat bank 1 0.03
Lambda probe after cat bank 2 0.15
I'm assuming this needs a new sensor and I know 227/228 can be due to an air leak but I have replaced those parts previously as they had split
65 NW-E-Error
I think this is camshaft sensor probably another replacement item?
211 LLFS error at mechanical jammed closed
I think this is the idle control valve and would explain why the car won't idle. Can these be cleaned with success?
242 Burning fail at cylinder 5
240 Burning fail at cylinder 3
243 Burning fail at cylinder 6
239 Burning fail at cylinder 2
On tick over I get the following
C1 0.443
C2 0.631
C3 1.148
C4 0.400
C5 1.362
C6 1.266
Once warmed up and holding it at 2k revs I get
C1 1.811
C2 2.589
C3 1.042
C4 2.772
C5 1.728
C6 3.983
Could this just be simply a change of plugs/leads?
68 Tank ventilation valve
No idea!
I would imagine some of these codes are being thrown up as a result of related issues in other areas but unsure which ones.
I'll leave the the other codes for the DSC for another day lol
Many thanks
Before Cat bank 1 0
Before Cat bank 2 0
65 NW-E-Error
C1 0.443
C2 0.631
C3 1.148
C4 0.400
C5 1.362
C6 1.266
C1 1.811
C2 2.589
C3 1.042
C4 2.772
C5 1.728
C6 3.983
No idea!
Many thanks
