My sterling grey E85 with updates
mm13
Buchholz in der Nordheide, near Hamburg, Germany
Z4 E85 3.0i
Hello everybody,
on the 8. January 2016 I´m buying a 2003 Z4 E85 with 115.000km (71457 mls).
Model: Z4 3.0i
Engine: M54
Transmission: Automatic
Color: Sterling Grey - 472
Upholstery: Lether Oregon / black - LASW
First modification: sell the Hardtop.
Second: selling the OEM rims and mounting Rial Salerno 7,5x17" IS34 with Pirelli Sottozero 3 (non-RFT):
Next step in the middle of the february: installing a Bilstein B12 with new wishbone´s front and Z-Performance ZP4 in Gunmetall (8,5x19" IS35 with 225/35 R19 front and 9,5x19" IS40 with 255/30 R19 rear):
All modifications with german TÜV... it´s sucks...
It´s wintertime, changing back to the Rial Salerno´s and time for driving with a lot of fun :)
Next Problem, entertainment from the OEM System: Navi Business (606), CD changer (672) and Hifi Loudspeaker (676).
Looking at the german forums www.zroadster.com and www.e90-forum.de... and found www.speaker-city.de
At the 5. March 2016, I am driving from Schleswig-Holstein to Bayern: https://www.google.de/maps/dir/Ruge...6b14f71b77757eb!2m2!1d12.1152567!2d49.3126185
Alex, from Speaker-City makes a good Job and 1 week later, I got my Z4 back.
What did he do?
Headunit Alpine CDE 178BT on Mosconi DSP6to8, amplifier Audison AV5.1K and Audison due.
Three way front System: Hertz ML280.3 + ML700.3 + ML1650.3
Subwoofer: JL Audio 10W3v3 S4 in a box at the footrest.
Footrest box:
Loudspeaker:
The Trunk with the active components:
The Sound: wonderfull :D
From Bayern to Köln, ehm sorry Cologne, Manuel from www.tiefenglanz.info brings the bright shine to my car:
beading...
Washing per Hand, polishing and giving a ceramic sealing from CQ-Quartz on paint and Windows.
Time do drive, got very much fun :thumbsup:
In the autumn, I thoght, I need a little bit more power :D
First step, light rims: OZ Alleggerita 8x18" IS40 with Michelin PSS 225/40 R18 88Y, weight 17,5kg :)
At the 8. october 2016 starting to www.schmickler-Performance.de :)
Setup the B12 and mapping the ECU (standard-mapping +10HPS more)
On friday, the 14. october I got the car back and driving to Alex from Speaker-City.
The Hertz 3-way-front-system deinstalled and we mountin the Rainbow Profi-Line System included the Subwoofer: PL-T28, PL-M3P, PL-W6C and PL-S10
The next steps in the next Post...
greetings
Michael
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Nice ZP4 wheels, you upgraded the front brakes too?
mm13
Z4 E85 3.0i
Next Post, next Upgrades:
Back at home, the Brake Pads at the front are finished...
3 Options: only change the Pads, upgrade to the Si-Brake (325mm Diameter) or the M3 CSL E46 Performance Break (345mm diameter).
Si Brake: no Problem with the german TÜV, the M3 Brake a little bit tricky but with help from friends from the german www.zroadster.com Forum no Problem.
What I need for the Performance Brake:
Brake Caliper left 34 11 6 786 741 (BMW)
Brake Caliper right 34 11 6 786 742 (BMW)
Brake Sensor 34 35 3 411 756 (BMW)
Brake Disc left 24.0128-0208.2 (ATE)
Brake Disc right 24.0128-0209.2 (ATE)
Brake Pads 13.0460-4848.2 (ATE)
Steel braided front lines 3cm longer then the regular rubber front lines
4 Bolts DIN219/ISO 12474 12.9 M12x1,5x80 mm
Serial Front Brake:
And changed to the Performance Brake:
I still working for an english DIY, it´s coming in a few days...
Minimum rim size 17", better 18":
Next step: H&R Anti Roll Bars
The Winter is coming (16/17) and time to change the rims...
If you ever drive with light rims, you never change back to heavy rims.
Looking and find the Motec Nitro 8x18" IS30 with Pirelli Sottozero 3 (18,5kg)
That´s the mods from the year 2016 :)
mm13
Z4 E85 3.0i
Hello,
5 little things, that I changed in 2016 too:
- Bastuck Rear muffler, TÜV-Version
- ///M-steering Wheel with multifuntion and ///M colour seam
- ///M-handbreak handle
- selector lever handle, complete leather and ///M seam, build by www.meinlenkrad.de
- Mosconi RC remote, controlling the power of the subwoofer.
In this year, 2017, my Zed had to go to the routine controlcheck (i.e. TÜV all 2 years).
The problem: the lambda was to high, no stamp, no driving...
To fix the problem, I change the Air Pump with Pressure Hose Assy and the Valve, 4 Lambda Sondes.
New TÜV-testing: all okay :thumbsup:
Time to have fun with the car and checking for new Upgrades :D
1. Upgrade: Performance Break rear, including german TÜV (did I say, it sucks, the german TÜV???)
What I need? A little help from two friends and I got the specs.
Break caliper from the E88 135i
BMW Partnumber: 34 21 6 786 743 (left) and 34 21 6 786 744
Brake discs also from the 135i, took the ATE-discs 24.0122-0257.1:
In the inner side was a V4A ring pressed, to fit the E85 park break to the size of the E88 disc size:
Now I am waiting for a good TÜV ingineer, that gives me the clearence to buil it.
When it´s ready, it´s Looks like that:
That´s all in this Moment, and I hope, you can read all, that´s more then 20 jears ago, that I write in english
greetings
Michael
David
Shoreham-by-Sea, West Sussex
Z4 3.0si Sport
Don't worry, your English is way better than (almost) all of our German! Thank you for sharing your car and upgrades with us.
mm13
Z4 E85 3.0i
Thank you, it´s a good training for me.
It´s a plessure for me, to share the Upgrades. Without input from other Zed owners, no updates for my Zed ;-)
Great works Michael, I'm guessing your TUV is equivalent of our yearly M.O.T. Test? Is the emissions test done every two years only? Your English is very good thank you.
mm13
Z4 E85 3.0i
Regular Name is HU (Hauptuntersuchung), colloquial TÜV.
We must test the car every two years, is the car okay: Brakes, rims, tires, engine, the Upgrades all in the vehicel regestration?
The emmissions test is a part of the HU, named AU (Abgasuntersuchung), without AU, no HU...
Here a Picture of my vehicel regestration:
mm13
Z4 E85 3.0i
Good morning,
6 month later, I still driving the car, the Bilstein B8 dampers are end of life, after 22 months and 67.000km (41,000 miles)
To do list 2018:
- changing the dampers, Koni yellow. (in the next 3 months)
- Oil-service
- Performance Break rear, 05/18
Trouble with the actually employer, changing to the 15. january '18, I hope, i got more time for this forum and more Money for the car :whistle:
DavidM
Ireland
I read your posts with interest - nice work on the modifications and good to hear there are more in the pipeline!:)
mm13
Z4 E85 3.0i
Thank you.
The greatest wish for my car: KW V3, adjusted by http://www.wwmotorsport.de/ , but this is a little bit expensive this year.
Some other rims, 18" or 19" from Schnitzer...
Changing to ///M-seats...
There is a lot in the Pipeline :whistle:
Good morning,
To do list 2018:
- Oil-service
Good luck with the new job Michael, more money and more time for the Z, got to be good!
Dino D
Kent
2.8 Manual
The Bilsteins didn’t last very long - were they leaking or just got soft?
Dino D
Kent
2.8 Manual
The front dampers leaking, the rear go soft.
The better way: Koni with Eibach springs, better quality of the dampers.
That’s not good great given the price of Bilstein I think. Especially as your roads in Germany are so much smoother. Might be worth contacting them as it could be a production issue.
mm13
Z4 E85 3.0i
News from my car: on easter saturday, I make a Little mistake :confused:
I scratching the front on a metal bollard, damage the right headlight and the front apron.
Now, the Zed got a new Headlight and new front for just around 4400€ :eek:
Next saturday, I changing the front bumpers.
Ouch! :arghh: Expensive :(
