My engine rattle
Sajk
Chain tensioner (one on side of block) replaced. Vanos replaced. Can't figure out what it is. Runs v well. Cat cams, remap, m54 intake manifold 24lb injectors so you know what's been done to it. It's difficult to isolate and sounds like it's coming from vanos but it's not. Rather than just keep throwing parts at it i thought someone might have heard this kind of noise before. Its much quieter when it's cold which makes me think it's hydraulic but I guess it could be a cat rattle also. Help please if possible.
View: https://youtu.be/vu6m_co2CPM
Sounds like a front pulley damper failing. Does it have a composite front pulley?
Belt drive vibration damper. So yes it does have damper. You will need to remove the drive belts then inspect the pulley to see if the rubber component is split. Hope you find it is as it would be a simple fix.
Sajk
Thanks Tony. What is the risk in driving it if that is the issue? I would guess it could fail completely and drop the belt?
Mine comes up with this part. This is the best pic I could find quickly.
Andrew
If it did come apart it could throw the drive belts off, shatter the cooling fan blade and take out the radiator. So possibly a lot of damage, IF it is the damper. Really does sound like it to me.
Sajk
Ok thanks. It sat for quite a few years and amazingly I did not lose many rubber components but maybe this one I did. Make sense why it is louder on the overrun if it's this. I guess louder when hot also as the rubber softens. Radiator out job?
Sajk
So Tony so I am clear this is actually the crank pulley Yes?
Yes. The only other possibility to produce that type of noise is the dual mass flywheel absolutely shot.
Sajk
@IainP
I can't really see the crank pulley from above as the fan is in the way. Will try to look at it from below.
@NZ00Z3
It is definitely working. I will try to reproduce the rattle when it's locked up.
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
Maybe remove it and see if the noise goes away. It could be the precursor to blades falling off etc.
Large screw driver/pry bar and a 32mm spanner. Left hand thread.
Sajk
Bad news. Had the car on the ramps and went over it with a stethoscope. Noise definitely from the top end. I think exhaust cam side. Everything else is quiet. ii's hard to tell at the top but i am pretty sure its the exhaust cam side of the head.
Mike Fishwick
French Zeds
Daglan, France
If you have air con, have you checked the bearing in the belt tensioner?
Sajk
Hi Mike, 99.9% sure it's in the top end. When i am undervtye car it's quiet down there. Having done more reading pretty sure its the bigger cams causing lateral movement in the vanos piston new vanos or not.
We pulling off the valve cover Monday to make sure nothing horrible is going on under there. I suspect a rattle kit is needed. Should have gone there first b4 replacing the vanos. Time will tell.
