- Joined
- Feb 9, 2021
- Points
- 14
- Model of Z
- 2.8
Hey y'all... constant lurker, been learning A LOT each time I work on my project '98 2.8 -- this will be my first dive into the engine, and it's a bit intimidating.
Not currently living where the Zed is stored, but trying to get a game plan together to tackle when I can work on her around the holidays. Had bought with multiple codes, cleared them, and the following keep popping up:
P1188 - Fuel Control Bank 1 Sensor 1
P0170 - Fuel Trim (Bank 1)
P0325 - Knock Sensor 1 Circuit (Bank 1)
P0330 - Knock Sensor 2 Circuit (Bank 2)
8 - Air Mass Flow Meter
57 - Knock Sensor 1
59 - Knock Sensor 2
202 - Fuel Trim Limit Bank 1
227 - Fuel Trim Bank 1
233 - Catalyst Efficiency Bank 1
As far as I can tell from my research, for this many and these types of codes to pop at the same time along both banks, it's probably an air leak somewhere? Is the P1188 likely the actual cause and all other codes are symptoms? If so, what is the best way to DIY diagnosing an air leak and where does this problem tend to present itself on the M52? If it's not an air leak, thoughts?
Apologies if this is covered in another thread... I probably just didn't search with the right keywords.
57 - Knock Sensor 1
59 - Knock Sensor 2
