I've recently purchased some brake calipers and vented discs from @gookah at ZedFest. The calipers and discs are removed from a 2.8 and from what I've read its a good upgrade to the stock brakes on a 1.9
The plan is to repaint these (although they do look brand spanking new), I'd like to have them a light blue possibly. But I'd be interested to know what others would suggest in terms of colour. Silver or black is a bit too plain for me and ideally I'd like some colour.
So first question is, what paint should I use - any particular brand that anyone recommends? Ideally it would be from an aerosol as that's a lot more fun than painting with a brush!
As I'll only be doing the job once, I may as well get a good set of discs. The ones that I got from Pete with the calipers are in good shape but I do like the look of drilled and grooved or dimpled and grooved discs.
Will something like this work for me?
From these two which is better in terms of pure performance? I personally prefer the look of the drilled discs but are there any disadvantages to the drilled discs compared to the dimpled ones?
I'll also be getting a good old decal to put onto the caliper and I've seen quite a few with the letter "M" on it, the decals do look lovely and I think it finishes the caliper off nicely but I won't stop hearing about it from the M Police
For pads I'll be going with the Red Stuff as I've heard great things about them but again I'm open to suggestions. Reason I chose Red Stuff is because of the reduced brake dust.
Also I'll be tackling the fronts first and will probably move on to the rear after a month or so, having a different setup (different pads and discs) at the front won't affect braking overall will it?
I'll be tackling the job in a couple of weeks once I have all the bits ready, I'll do my best to document it should anyone else want to upgrade the brakes on their 1.9.
Thanks.
Thanks.
