So managed to get the Zed through this years test. Failed initially on front nearside suspension arm and boot
and a tyre.
£256 all sorted.
Needs front brake hoses.
and a tyre.
£256 all sorted.
If you're going to change them , change them all, for stainless steel braided ones. Job done, once and for all.So managed to get the Zed through this years test. Failed initially on front nearside suspension arm and boot
and a tyre.
£256 all sorted.
Even stainless braided hoses have "rubber" inners. It's just that you can't see them degrade.If you're going to change them , change them all, for stainless steel braided ones. Job done, once and for all.![]()
Rubber hoses are also made of two seperate parts, an inner "tube" which carries the fluid and an outer"sheath" which is there to protect the inner part.Even stainless braided hoses have "rubber" inners. It's just that you can't see them degrade.
