If you took up the option of an Extension on your MOT earlier this year here is something you should be aware of.
Defect | Category |
(a) Brake lining or pad: (i) worn down to wear indicator (ii) worn below 1.5mm | Major Dangerous |
(b) Brake lining or pad contaminated with oil, grease etc. | Major |
(c) Brake lining or pad missing or incorrectly mounted |
Interesting thank you. So that’s why they wear. And my missus is a very light braker so that makes sense.Discs wear like that because there is no Asbestos in the pads anymore Rob. I changed the rear discs and pads on the oil burner earlier in the year and I know i have to do the fronts before MOT time early next month. This because the insides are corroded and pitted because of light braking all the time. It certainly does not hurts to giver your brakes a beasting now and again to keep the discs clean when it's safe to do so, although "fly by wire" throttles make it difficult to do because as soon as the brake lights light up the throttle is "killed" so you only get one hit at a time unlike the old days when you could ride the brake and throttle together. At least you can clean the Parking brake like this.
Thanks Tony. It was actually a service where you might think a main dealer would take the opportunity to recommend a set of discs/pads. But they also know it's a lease car and my missus doesn't want to spend money she doesn't have to. Not my way of doing it. But 14 years of her Royal Rightness has taught me not to argueYes, you answered your own question there mate. You have to remember that the MOT test is looking for the minimum acceptable standard only. As you say, we, as enthusiasts do the opposite sometimes.
