MOT and prep
Just a quick question, coming from the oil & gas biz, I know that above is done all the time but does it not change the mechanical properties of the material, as 'heat treatment' will harden the material.
Bolts yes, but you will replace them, flanges and pressed steel no, as they are mild steel so no transformation until after 900 degrees.
