After making a new work table top for the B&D Work mate I picked up for a fiver. Today I fitted some threaded inserts so I can bolt down my router table. I used these type of inserts.
First I had to take of these rubber feet
then mark through the holes onto the table top once it was centralised. Drill.to the size of the small end of the insert then screw the insert into the table top with a 6mm Allen socket.
Top showing screws in positioin,
but you don't need to leave these in as the inserts finish just below flush with the surface and the excess insert underneath can be trimmed with a cutting disc. When it's screwed down it looks like this.
Following on from yesterday, clamps removed and trimmed on my drum sander I made last week. The mystery object looks like this.
Still waiting for bits for this but more tomorrow. Gotta keep busy.
