MOMO Steering Wheel
Discussion in 'Z3 M Roadster & Coupé' started by Rocket Ron, May 18, 2014.
  1. Rocket Ron
    Rocket Ron Regular Member
    Mar 30, 2014
    42
    9
    18
    Manchester (UK)
    Model of Z:
    Z3m Coupe
    I have successfully fitted a MOMO flat bottomed steering wheel, No airbag of course but the horn button is remotely operated via a unit mounted on the wheel with the receiver behind the Radio all wired so its easy to replace original for MOT test It makes a fantastic difference to the feel of the car and easier for me to get in & out 1 happy chappy Rocket Ron.
    • Like Like x 3
  2. swamper
    swamper Zorg Guru (V)
    Supporter M Power
    Dec 4, 2011
    2,593
    813
    181
    Mossley
    Model of Z:
    z3m
    pics please?
  3. zedonist
    zedonist Guest
    How will you get past the MOT and how have you got past the Airbag light, and as per Swamper pictures please.
  4. Rocket Ron
    Mar 30, 2014
    42
    9
    18
    Manchester (UK)
    Model of Z:
    Z3m Coupe
    Hi I,m not good with pics but will try later! Airbag light + 3 ohm resistor across the circuit = MOT Its quick & easy to refit original steering wheel & Airbag,the light will work but the airbag wont ( that cant be tested anyway) Happy motoring Ron
  5. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,183
    9,325
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Uploading pictures instructional, or if you get stuck email them to me and I'll put them on for you Ron!
    View: http://youtu.be/qAD2dOMdh-s
  6. Rocket Ron
    Mar 30, 2014
    42
    9
    18
    Manchester (UK)
    Model of Z:
    Z3m Coupe
    Hi Gaz its getting the pics onto the confuser thats my problem
  7. GazHyde
    Dec 2, 2011
    15,183
    9,325
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    You'll need to post me your camera then =))
    • Funny Funny x 1
  8. hard top
    hard top Zorg Expert (I)
    Dutch Zeds The M44 Massive
    20,779
    6,062
    213
    Netherlands
    Or the memory card.......;)
    • Funny Funny x 1
  9. captain
    captain Regular Member
    South African Zeds
    Sep 19, 2012
    81
    24
    24
    Durban, South Africa
    Model of Z:
    Z3 Roadster 2.8i
    Did the same on mine
    [​IMG]
  10. Stormy_be
    Stormy_be Zorg Guru (I)
    Belgian Zeds
    Oct 29, 2013
    745
    470
    97
    Belgium, ieper
    Model of Z:
    Z3 2.8 Roadster
    Which steering hub did you guys get?
    Will still need the hub to fit my race steering wheel.
    Was also looking at removable hubs.
    But then you always have the rack to the racing hub (6 bolts flange) and then the removable hub on top of that. Never found it directly in 1 piece.
  11. captain
    South African Zeds
    Sep 19, 2012
    81
    24
    24
    Model of Z:
    Z3 Roadster 2.8i
    It's a momo hub
  12. Rocket Ron
    Mar 30, 2014
    42
    9
    18
    Manchester (UK)
    Model of Z:
    Z3m Coupe
    Hi Gaz Nice 1 I might just do that ! lol Actually it is quite a reasonable camera but my computer programme doesnt like it .
    The previous programme did & there was very little problem I dont have a lot of time but what may work is to take the card out of the camera & download it Give me a little time ,. Regards Ron.
  13. Rocket Ron
    Mar 30, 2014
    42
    9
    18
    Manchester (UK)
    Model of Z:
    Z3m Coupe
    Hi how did you get the horn to work? With Part Number 32311158475 ? I,m still waiting for this to arrive, meanwhile My remote system is OK Ive stuck the button on to a spoke of the wheel with Bluetack My biggest difficulty was picking up the connections for the horn in the plug under the wheel ( 2 very small pins ) I found a plug in my junk box( always handy) I didnt want to permanently alter the existing wiring
    #13 Rocket Ron, May 19, 2014
  14. captain
    South African Zeds
    Sep 19, 2012
    81
    24
    24
    Model of Z:
    Z3 Roadster 2.8i
    I had no problems with the horn, the original slipring fitted to the momo hub.
  15. Rocket Ron
    Mar 30, 2014
    42
    9
    18
    Manchester (UK)
    Model of Z:
    Z3m Coupe
    Hi It must be a different system on the M coupe it doesnt have a slip ring on the original wheel only a coil inside the Airbag unit, Just My luck but I have had to rely on Skill & experience to solve this problem LOL the new hub does have a slip ring but there is no brush to make contact .
    I have tried to order the part ,Keeping my fingers crossed
  16. captain
    South African Zeds
    Sep 19, 2012
    81
    24
    24
    Model of Z:
    Z3 Roadster 2.8i
    I'm sure you'll get it sorted :) when I was looking for a hub I found there are a lot of different types, took a while to find the correct one.
  17. Stormy_be
    Belgian Zeds
    Oct 29, 2013
    745
    470
    97
    Belgium, ieper
    Model of Z:
    Z3 2.8 Roadster
    I suppose that is a non-removable hub?
  18. Rocket Ron
    Mar 30, 2014
    42
    9
    18
    Manchester (UK)
    Model of Z:
    Z3m Coupe
    Absolutely not It is held on via the same bolt as the original Airbag hub/Wheel! Ive modified the wiring a little to accommodate a remote relay Which should be a non latching type but everything is easily & quickly reversible for MOT Tests the airbag light operates as it should & the air bag operation can be re installed if required Simples ! Maybe 1 hour tops for the whole conversion & 1 hour to reinstall the bypass & new wheel with the remote button on it after the test
  19. Stormy_be
    Belgian Zeds
    Oct 29, 2013
    745
    470
    97
    Belgium, ieper
    Model of Z:
    Z3 2.8 Roadster
    As my car is a trackday only car, I don't care for the airbags (useless with 4-5&6-point harnasses) or for MOT.
    But removable would be nice.
