jaguartvr
- Joined
- Jan 9, 2017
- Points
- 95
Have a recurring misfire, it only when the car is sitting at tick over. Starts and drives fine but when you stop and the car is ticking over it starts to misfire and the engine light comes on. Pop the scammer on and it comes up with various codes, P300, P302>P306 which mean misfire on various cylinders, different each time. Scan and clear the codes and it is fine until it sits at tick over again. Doesn't happen every time but it's annoying.
Does anyone have any idea what it could be?
Battery did have a fault and kept losing its charge but I have just replaced it and no difference.
I can use the scanner on the port under the steering wheel but can't read anything from the plug under the bonnet, it's a 2000 2.8.
