Milky paint
Discussion in 'Summit Detailing' started by si-forks, May 2, 2013.
  1. si-forks
    si-forks Dedicated Member
    451
    2
    34
    worcester
    Model of Z:
    1.9
    Looking for some help with what to use on my bonnet ! the paint is sapphire black metallic and its an 06 Z4 , I have a DA and have detailed most of the car using scholl 17+ and meguiars ultra cut compound 105 with geart effect on the rest of the car:D but I cant get a decent finish on the bonnet :(
    17+ has impoved it a little as did meguiars paint rejuvenator but it still has a milky look to it any ideas !!:) thanks
    Sent from my GT-P3110 using Tapatalk HD
  2. zedonist
    zedonist Guest
    Has the bonnet been refinished and lacquered? A poor prep could cause condensation or wet base below the lacquer, which would require a strip and repainting. Hopefully it's not and just needs a bit more elbow.
  3. Summit Detailing
    Summit Detailing Zorg Addict
    British Zeds Resident Detailer
    Apr 20, 2013
    144
    129
    64
    Portishead, Bristol
    Model of Z:
    Mercedes C320CDI AMG Sport Estate - Tenorite Grey
    Difficult to say without seeing it. By milky do you mean a dull, washed out finish? Poor gloss & lacking decent reflections?
    It could be numerous things, have you owned the car from new? If not it may have had the bonnet resprayed at some point in the past & has either been prepped or finished poorly.
    You could try taping off a workable section & using the most aggressive combination of pad/polish set about doing 2 or 3 sets (leaving a few minutes between sets), refine as I presume you've done with the rest of the car & see if it results in an improved finish?! If so then you know what is required. If not then the next step would be for someone to try a more aggressive approach with a rotary/wool pad and/or some wet sanding. Last resort would be a repaint.
    Chris
  4. si-forks
    451
    2
    34
    worcester
    Model of Z:
    1.9
    Thanks for the advice
    Si-forks is tapatalking
  5. si-forks
    451
    2
    34
    worcester
    Model of Z:
    1.9
    http://db.tt/NeuGiOg4
    Hard to see in this pic but the bonnet is dull in normal light in stronger sun light look ok
  6. Summit Detailing
    Apr 20, 2013
    144
    129
    64
    Portishead, Bristol
    Model of Z:
    Yes, that pic doesn't give anything away.
    A better pic would be with the sun on it, stood at the front of the car with the camera pointing directly down on the bonnet.
  7. si-forks
    451
    2
    34
    worcester
    Model of Z:
    1.9
    Ok been doing a bit of Googling and some people think the cloudy ness is caused by degeneration of the clear coat ,because of heat from the engine ?! And shows up more on black cars !
  8. Summit Detailing
    Apr 20, 2013
    144
    129
    64
    Portishead, Bristol
    Model of Z:
    Hmm! I'm not convinced, maybe if its been repainted at some point previously & it's not been the best of jobs that may be plausible. OE factory paint will not degrade as you've said.
    Compared to a big Italian v12 a Zed engine barely gets warm ;)
  9. badman gee
    badman gee Guest
    I'd go for a repaint causing it!
Share This Page
