- Joined
- Dec 4, 2011
- Points
- 226
- Location
- Langley Mill
- Model of Z
- Z4 3.0si Individual Ruby Black Last one produced in this colour combo
Well i used the Meguiars Ultimate Polish for the first time and this is what i found. Black Coloured Z4
You need to do what it says in the instructions.
Do a little area then buff off
If this polish is put on more than one panel at a time it is very hard work to take off and buff up and when completed you have to go over the panel time and time again to get the panel back to how it was before using.
I put this on the Bonnet, wings and rear end then took off (never read the instructions), when i had finished there were smear marks still on the paint and i had to use my PH Neutral quick detailer to get the bonnet spot on.
If done as per the instructions then it is ok but I have to admit i will not use this again as i can get a better finish with the Menzerna Final machine polish putting it on by hand and buffed off a panel at a time, again this is very hard to take off if doing more than one panel at a time but does not leave the smear marks.
The Meguiars Ultimate Polish is for doing a full final polish of the Car
Do not use it if you just want to give the car a quick polish as the Meguires Ultimate requires time to do, due to you only being able to a small section at a time
I will for a quick wash and polish stick to the AG Super resin if i just need to give the paint a top up and if i want to spend my time giving the Z a proper polish then i will use the Menzerna Final finish polish before waxing.
