Been a very productive few days. Parts are finally starting to arrive.
First job was fitting the new beam bushes and reassembling the rear subframe. Love how you can see the factory markings on the diff casing.
can see the factory R stamp indicating it has an LSD fitted.
gave it all a wipe down and it’s amazing how clean it is.
then minutes later I had it back up in the car.
at this point I always fit the shocks so the rear end is supported. New Sachs shocks
new fasteners in the right places to make future removal easier. Removed the cap heads for flanged hex.
The following 3 hours is just a methodical reassembly.
Replacement springs also fitted.
the main photo showing the biggest reason all these builds take place. Finally the beam bushes supporting that beam.
Some new flanged nuts for the exhaust. Always find these past their best.
With the back end now done. I moved up to the front. All the hardware here is being replaced.
Was funny I needed to remove the callipers to hang out the way and one of the brake pads now identifies as wireless.
Will get some fresh discs n pads in the morning
good few hours in and all the old stuff removed.
I always leave the wishbones till last.
both front hub assemblies
shocks also waiting to be replaced
Now all gutted
some of Meyle’s HD finest to go back on.
This is how far I’ve made it in the last two days. At this rate she’ll be done by the weekend.
