lowering the roof recently the roof dropped a bit quickly, sort of slammed down. So I took the assist strut out & it was Knacked, check with dealer, then looked at suppliers. I found this one SGS Engineering solutions in Derby. Sent them my duff strut & got a replacement at about third less than dealer including VAT & delivery just over £29.00. Fitting no probs roof now much easier to drop & lift.
The part number is GS10-22-120-170 you will only need this if you remove the ball joint off the lower end & the sleeve & ball joint off the top. I had a new ball joint on the bottom, cheap laugh!! it's a B18.
the strut piston is a bit larger diameter but there is loads of room for it.
hope this is usefull
