M54 conversion
BillyHughesZ3UK
Hi Guys
i have acquired a 325i sport 2003 auto, id like to swap the engine into my m43 z
before i continue i dont want people telling me it would be eaiser to by a 3.0 blah blah.
if i didnt want a project i wouldnt be here.
So i know i need the correct manual box which i have sourced.
looking for a diff
i need medium case drive shafts
and obvislouy the engine
what else do i need to rip off the 325 for my conversion
also is there any threads where people have done this ?
Tia
mrscalex
It’s more a case of what you don’t need. For starters:
DME, EWS & lock set possibly from US as no UK 2.5s. Or DME with EWS delete
Engine loom
Uprated front brakes
Exhaust
Air box & intake hoses
Radiator
I don’t think you’ll find a how to on this as most would consider it an unusual start point.
I shouldn't be a huge job, You'll need a logical approach to it. Take one step at a time.
For what your using you should be able to mate the engine up to the existing gearbox. Unless you have the ZF box on the 2.5 use that. But you might need to use the GEtrag box to mate the flanges on the shaft.
The engine mounts will line up, engine loom will cross over (plug n play) You'll need an EWS delete ecu to get you running. The fuel rail should cross over ok just make sure you have a release valve either on the rail or filter.
Quite a few details like this on my engine swap thread.
The 325 bhp is not much more over the M43 so you could get away with the existing running gear, it might launch like a missile due to the final drive, if thats an issue get yourself a 3.15 ratio diff.
Edit: just seen its an auto, getrag box it is.
