Davyhoogy
I need 3 bits of advice from those of you that have the m50 conversion on your pre facelift 2.8.
All the instructions I can find are for e36s so cant find where these 3 pipes go.
If someone knows or can nip out and have a look on their car then it'd be much appreciated.
I did label as many as I could but obviously just missed these.
First one is a tiny tube that comes off the rear underside of the manifold.
Next one is from the centre underside of the manifold, by the book it says it needs joining on a secondary air pump but I dont have one of those I dont think? Does it go to the next one I'm unsure about?
Last pipe I'm not sure on here.
Only other thing I can think of is that it's now the 2nd one I wasnt sure on?
It used to fit here on the m52 manifold
