Zmirzephyr
Alright so this has only been an issue for a couple of times during hot summers in heavy traffic. Temp needle starts to climb.
The coolant has not been changed for at least 10 years, and the car has mostly been sitting. It looks fine but it's something I'd like to change at some point.
I've understood these older bmw's suffer from bad water pumps and, I know for a fact no one have tinkered with it since 2007. Had some collegues recommending me to change that out to rule out a cracked/damaged impeller. I also need to do the drive belt and the generator bearing or whatever it was called. Meanwhile get that coolant changed.
Sounds like a good plan?
