M44 disa valve replacement
Kenny101
Essex
Hi all
Just before i pull the trigger on an OEM disa for my 1.9 m44.
I was wondering if anyone has had success using an aftermarket unit. As im sure you all know they are not cheap
any advice will be much appreciated !!
thanks,ken.
mrscalex
Not recommended from what I have read. Aftermarket not good qualty. You are better off with secondhand in my view if you want to save pennies.
If you want to go that route PM me as I have a spare.
If you wait till later I have just overhauled 3 disa valves all ended up having same issue thread coming up later.
Kenny101
Essex
@Kenny101 whats up with yours
Sunday i was changing some bulbs and noticed a clear ticking noise that i had not heard before . It took all of one second to figure out it was the DISA
im gonna pull it tonight and ill let you know what state its in
For thread information to remove disa valve on a M44 first remove 10mm nut ( top right ) this will allow the dipstick tube to be moved just out the way.
Underneath the tube bracket another 10 mm nut ( double threads to secure disa and distinct top right only) then remove the other 2 10mm bolts in position as arrowed above.
Once all bolts out with a bit of a wiggle it should withdraw from manifold.
Once loose withdraw a little to allow access to multiplug on the bottom left
Multiplug is removed by pushing the metal bar on plug in towards centre of plug and withdraw it.
Once plug off you can fully remove disa.
To do so on mine required just to pull back the abs pump a mm or so to squeeze disa past it so withdraw turning towards front of car will come out
refitting is reverse of removal.
Kenny101
Essex
View attachment 146283 View attachment 146285
For thread information to remove disa valve on a M44 first remove 10mm nut ( top right ) this will alow the dipstick tube to be moved just out the way.
Once loose withdraw a little to allow access to multiplug on the bottom leftView attachment 146289 Multiplug is removed by pushing the metal bar on plug in towards centre of plug and withdraw it.
To do so on mine required just to pull back the abs pump a mm or so to squeeze disa past it so withdraw turning towards front of car will come outView attachment 146291 View attachment 146291 refitting is reverse of removal.
Thank you very much for that information, i planned on pulling mine this evening but ended up working late so this is gonna be a weekend job
Kenny101
Essex
Just wanted to add that i have seen refurbished OEM units which I may take a punt on , maybe ?? Only has 6 reviews but all very good and from the description of the rebuild sounds good ?
I watched a video on refurbishing an m44 disa and after watching it and dismantling my faulty one concluded that I could do cheaper as from what i had watched overhaul consisting mainly with diaphragms replaced .The electric motor as long as working does not get touched ( upon inspection appears to be a sealed piece so no access without cutting the back off it)
