M Bumper air scoop
Sean d
Lincolnshire
I've been thinking about making a scoop for the M bumper for a while and today I got some inpiration from a block of foam That I found in the yard at work, Its designed to drive the air straight up to the hole behind the headlight where the induction kit will sit, at this stage it is just a mould.
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Great idea, would you use flexible hose to get the air up to the air box?
Sean d
Lincolnshire
The air box has been removed and replaced with a Ramair filter, its pretty close to the scoop under the head light so I don't think it will require any hose as the air should be driven in that direction.
5harp3y
You can buy ducts from demon tweeks that could attach to that into a hose
