- Joined
- Mar 15, 2015
- Points
- 191
Firstly a big thank to @Lee for giving up his evening to fit my 30mm Eibach Prokit Lowering Spring
I arrived at Lee's before he managed to get home from work and as soon as he did the garaged door was opened and Lee was straight on the job.
Front Springs
Rear Spring
Spring Press
While I was there Lee was good enough to check why I had a noise driving as tho something was rubbing.
What was found was one of the little springs that hold the hand brake shoe to my corroded disc back plate had pulled through it's hole. There was no time to replace the back plate so a temporary fix was applied
You can clearly see the difference on the head of the spring
The difference in height is recorded
During the installation @Shortie_gal - Sam arrived home from work driving her lovely Z3 and as always it was nice to be able to spend some time with Sam.
Sam sorry for steeling your evening with Lee
Once the job was done Lee took me for a spin in my Z3 and I'm sure he was trying to roll my car I simply could believe my car wasn't on rails.
Lee did say how smooth my gear box was so I'm guessing this is because @NODZED - Niall replaced my gear box oil also the diff oil was replaced at the same time
Since using the Zed Shed my Z3 isn't the car I purchased, it's sooo much better.
Front Springs
Rear Spring
Spring Press
