Lowering and camber advice
Gwyndaf
Caernarfon
Z4M R and Z3M R
im fitting my BR racing coilovers and h & r lowering springs, what are peoples experience of the optimum setup in terms of ride height and camber for road use.
Dino D
Kent
2.8 Manual
Which spring weights did you go for?
I had mine corner weighted and aligned at an MX5 specialist with racing experience.
He wanted to get 1,5-2 degrees camber on the front but could only get 1 degree in both sides for some reason (something about how much adjustment there was available). It feels great with a bit of camber on.
@Lee had my car set up pretty well from his garage floor so was only a little bit of adjustment was needed to get it to what I wanted (my brief was low as practically possible without grounding/rubbing and set for enjoyable road driving):
The specs on mine are now:
Weight of driver: 75kg (the actual drivers a bit heavier now..!)
1/4 tank fuel.
LF 335kg RF371kg
LR 338kg RR364kg
Cross weight 50,3%
Total weight 1406kg
Ride height
LF 5"9/16 RF 5"8/16 (from front ARB)
LR 7"7/16 RR 7"3/8 (from rear beam)
Camber -1 degree both sides (front)
Front toe: 0,5mm toe in
Lots of BC racing talk on this thread:
https://zroadster.org/threads/project-dino-d.6735/page-5
Gwyndaf
Caernarfon
Z4M R and Z3M R
Thanks great help,thanks. This driver is much heavier. I know that Lee is busy with his TVR otherwise id send him a pm.
I sent the TVR out for its work so feel free to use my services.
