Z3m roadster 2000 gauge lights,right tail light, front right side light, and gear shifter light all not coming on. Changed fuse and it keeps blowing. Any suggestions welcomed. Tx
matter of finding the short circuit that's blowing the fuse. Disconnect each unit one at a time to see if fuse stops blowing when it does you will have found the short. Check all wiring serving each unit for damage that could also be the cause of the short.
