lighting problem...
David Cullen
Prosperous, County Kildare
well guys, another issue has popped up for me, I seem to have lost my low beams...
first off it was that they didn't turn off so I took out fuses 11 and 12 so as not to run the battery down, I went to scrap yard to pick up a new switch and put that in, there was no light now... I took apart my old switch and had a look at the pcb board and all was ok, springs on contacts were ok so put it back together and swapped it for the new one, same issue but with the lights off this time...
I checked for power on the block connectors for the lights and there was none, checked for power on fuses 11 and 12 and there was none, then checked power to fuse 25 and there was power, so, I am guessing there is a relay between fuse 25 and 11 and 12 that may be sticking... any ideas? thank you :)
Had a 1999 728 in for test the other day, no dip beam. Needed 2 bulbs! EASY fix.:)
I guessed as much Dave. Years ago I worked at a Chrysler dealership and the 2nd generation Alpines had a nasty habit of when a dip beam bulb blew it took the other one out with it. But another quirk they had was if you were careful with the dip switch you could have both dip and main beams on at the same time, and boy were they good lights. Must have had some good wiring though.:)
Old tech though, 35 years ago!;)
