lean machine !
graeme cook
Hi all ,
I have a 2. 0 facelift car , I have had the po170 and po173 codes'#, plus misfire on 1,3 and 2 cylinders . so normal thing to do, vac pipes replaced and dissa valve .
how ever she's a bit sluggish and from what I can see from the exhaust very very lean . i have cleared the codes on my code reader but I assume these will
been short term codes not long term codes ( they haven't come back ) but we are still running very lean and drinking quite a bit of fuel.
any suggestions ? cheers
graeme cook
Hi I Have checked the vac hoses , but still does solve the lean ? if there's a leak in the vac hose (more air getting in) surely the sensors would compensate and add more fuel
It can only add so much before it Max's out.
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
With a hot engine at idle, check the 4 fuel trims (2 short term and 2 long term). Let us know what they are
graeme cook
Hello , thank you i will get my friend to have a look , my reader i don't thing does long term codes .
