hi guys....My soft top has developed a small leak at both the drivers side and passanger side where the roof locks into place. I have checked the seals and there are no real sings of wear and tear. The drip seems to be coming from where the pin goes into before being tightened by the callipers. Is there any way to tighten the hood as I had an MG before and you could tighten the hood with two screw bolts attached to the screwed rod that attached the hood to the windscreen frame.
Many thanks.
Many thanks.
