GwenU
- Joined
- Jul 17, 2018
- Points
- 14
Hi, Last week we put a hard top on our 1999 1.9 Z3 as we were experiencing the odd water leak and just assumed it was the soft top leaking and we do not have access to a garage (just a car cover) The rain and wind has been pretty bad over the last few days and the car cover was blown off. We left the cover off as it got so wet on the inside. We then discovered the water has been pouring into the car from the front A pillar sill where the window corner meets it.
I have done lots of internet searching and learnt loads more about the car through Utube and useful links and information posted on here. Looking at the rubber at the top of the pillar where the window sits it sticks out both sides far more than I can see on any other car that has been repaired with silicone. I hopefully will post a couple of pictured to show you. Does it look like its worth trying to repair or does it look to far gone/out of shape and I should just bite the bullet and spend out on a new seal? Or do you think it has just been pushed out of shape when the hard top was fitted?
From what I can see without taking the hard top off it is one long seal that goes from bottom of one door up over the top of the window and down to the bottom of the other door. Does this sound right?
Thanks in advance Gwen
