Not sure what a leak detection pump is if I'm honest. There's an auxiliary air pump (known colloquially as the "Smog pump" in the USA) . If that's what you're looking for it depends on which engine is fitted in your car 4 or 6 cylinder?. You can remove it depending on where you live, I believe in California they're still required.
