Lambda Sensors
Paul H Johnson
Morden, Surrey
3, 2.8 auto
Hi all, a few quick questions for you !! My 1997 2.8 has just failed its MOT on emissions. On inspection by the tester, he found that the wires from the post cat lambda sensor had been cut off, leaving the sensor itself as a blanking plug !!! When we investigated further, there was very little evidence of the route of the cable or where it connected back to the on-board computer. The pre cat sensor & its connection are in place & are easily visible. My questions are: Does my Z3 normally have 2 lambda sensors & if so, what's the cable route & where does it connect ??? I hope someone can help !!! Thanks in anticipation to any of you that knows the answer !!!
Rgds
Paul J
jonco
Chester
'98 1.9 Auto
oem parts site shows pre cat and post cat sensors here ....
The post cat (item 17) is faded out and not included in parts listing. I thought this meant not installed on this model.
Your right, shaded out so not fitted to yours, can only think your exhaust is not the original otherwise I would have expected a blanking plug, they wouldn't have put a sensor in there to act as a blanking plug.
