Koni or Bilstein struts???
TexasZ3
I have just replaced the original (1999) rear shocks with Koni 8040 1217 sport and now need to replace the front struts. After researching this further, I now see a lot of BMW and Z3 owners on You Tube saying Bilstein are the best! I am looking at Koni 86411 1338L SPORT (left front) and 86411 1338R SPORT (right front). The Bilstein equivalents are 35-044024 B8 and 35-044031 B8.
My two questions are.
(1)Does anyone have any experience of using either of these struts
(2 if I decide to use Bilstein, is it OK to have Koni on the rear and Bilstein on the front? Thank you.
Zephyr
Many parameters make them different, like damping stiffness, length, rebound etc.
i had Bilsteins (B8) on an Audi TT and never liked them for street use. very hard and you could tell head from tails if you run over a coin. (Maybe combination with the lowering springs I had installed).
for track use they were fantastic but track was 10% of the use of that car.
Stick with Koni, nice to have a predictable setup.
cheers.
Bilsteins at one the front and Koni at the rear will be fine.
TexasZ3
cheers.
TexasZ3
Thank you so much for your feedback. Definitely do not want that kind of ride. :)
If the car is not lowered or fitted with sport OEM springs best use B6s, B8s have a shorter rod for lowered cars. The shock performance is however the same between B6 and B8.
TexasZ3
Nodzed thanks for the feedback. The springs are original so car is not lowered. I am having trouble in the US finding B6 for my Z3, Bilstein recommended standard or B8's. I am still searching.
Sorry that's not correct, if its standard springs B6, if lowered B8
This is from Bilstein.
