Knocking / metal
Gizmo
Morning,
at low speeds, I get a coupe of noises.
one bring a metal on metal sound - hard to say if it’s the rear or front. Sounds like thin metal almost tinny sounding. Generally when I go over pot holes.
The other sound is more of a knock, thump maybe. Generally at low speeds, when I’m off and on the throttle.
any ideas of where to look at, would be fab.
Thank you,
Ian.
Gizmo
Pingu
Heat shield? Brake backplate?
Try jacking a front wheel off the ground and spinning it.
If you have an LSD, you will need to jack both rear wheels off the ground and it won't be very easy to spin them, but you can turn them.
