ok so on my M44 (I have sooo many Z3s, don't you know ) it's really hard to start and when it does there's white smoke out of the exhaust. I decided to whip the valve cover off in prep to 'whip' the head off and change the gasket, there's a small amount of cream froth on the oil cap but not much in the valve cover. I took the spark plugs out and pots 1 & 2 were oil/grease fouled on the spark plug itself and the long plug cap. I've done a compression test on all pots and 2, 3 and 4 have a healthy 175 and above whereas pot 1 is barely over 50. should I put some fuel injector cleaner in the pot get rid of any crap around the rings so they can seal again, or is it just going to be a case of taking the head off and change the gasket?
