Is there a difference between a manual and electric roof?
id101
Obviously there is, but i am referring to the actual roof assembly, I see 2nd hand ones for sale is there a difference? As I have also seen electric roof conversion kits and its just the the hydraulic ram and other bits not the roof itself. So do they all work if you already have an electric roof fitted?
AirOps
N.W. Vermont USA
The roof frame is the same, the difference is that a manual roof uses a gas strut to assist in the opening and closing and the electric roof replaces the gas strut with a hydraulic strut and adds the hydraulic pump necessary to operate the strut.
AntStark
Hampshire
2002 3.0 Sport
It’s not particularly difficult but is time consuming..I am waiting for a sunny weekend to change my roof frame. I bought a second hand manual roof frame to replace my broken electric one. Will swap everything over. Can see getting the switch wired in through the roof frame will be a little tricky.
id101
cheers all, i need a new electric roof you see and wondered if ones listed as manual would work
id101
i can get a roof missing the switch but the seller has said they'll include a switch and wiring, anyone know of any guides of hand of where the wiring goes in terms of routing so there are no snagging or breaking issues?
AntStark
Hampshire
2002 3.0 Sport
It goes through the frame itself at some point.. I'll try take some photos of mine later. There is probably a Your Tube vid somewhere of it being done
id101
cool cheers, i'll have a look through youtube
