Interior screw questions
97Z3
Somebody took apart the shifter surround trim and the corners of the glove box trim and to the right of the column to take the radio out?. My kid said he tried to put the screws back in (pretty sure it's the oem screws that po left in the cup holder). He said it feels like there is nothing to screw into.
There is at least one maybe two plastic triangle looking blocks with metal thread clips. Do those belong on the dash structure behind this loose trim?
The metal trim on the side of the shifter tunnel, assuming those screws come from the inside, how do we access those?
Going to try to revive the obc and then only two other issues to sort out. Fuel gauge comes and goes (mostly goes) and driveshaft clunk which isn't quite as bad as I originally diagnosed.
