Interior light dimmer wiring question.
ExMX5owner
Moderator
Staff member
Australian Zeds
Queensland, Australia
Anybody up to speed on the wiring of the light above the rear view mirror, where does it run from and where does it terminate ?. Just asking because I would like if possible to use the self timer and dimmer feature off that circuit. 99 model with auto-tint rear vision mirror and it's associated wiring, I imagine its all in the same loom..
Althulas
Banburyshire
M Roadster
This thread might be of interest.
ExMX5owner
Moderator
Staff member
Australian Zeds
Thank you , that's a start..:thumbsup:
I can tell you the wiring for the interior lights runs down the right a pillar ( 99 rhd ) to the right hand side once the lower dash section removed .
If memory serves runs into another section of loom there not sure where goes after that ( didn’t need to know with what i was doing)
I tapped into it there when i wired in my footwell lightning.
Stephen.
ExMX5owner
Moderator
Staff member
Australian Zeds
Stephen.
Thank Stephen, that helps, because it's exactly what I want to do... :thumbsup:
Cant find the 2nd part as yet with the wiring side . its on this forum somewhere.
Stephen.
ExMX5owner
Moderator
Staff member
Australian Zeds
Stephen.
Ill have a hunt for the second bit, cheers Stevo...
Found
Another thread i had posted at the time once finished.
Stephen.
ExMX5owner
Moderator
Staff member
Australian Zeds
Stephen.
Looks great, I,m just going to be using miniature 12V Leds, stuck on in discrete places, where they cannot be seen in themselves. I can't find the wiring bit Stevo, but what you have already said is enough for me to track the wiring down with a multitester.. Thanks mate...
