Inspection II and pre MOT check
Braz86
Aylesbury, Bucks
Not as painful as I was expecting, she will pass with many advisories apparently. Might have to make a few trips to the zed shed though....
Thought the airbag light on was a failure o_O
Braz86
Aylesbury, Bucks
They reset that, it was more a note of what the fault read.
Should I replace the whole wishbone mount, or just the perished rubber?
gookah
Shropshire
2.8 Z3
Airbag light on is a fail nowadays.
MOT manual extract:
7.1.6 Supplementary restraint system (SRS)
Defect
  1. An SRS malfunction indicator lamp (MIL) indicates a system malfunction
Major
Missed a bullet there with the reset.. :thumbsup:
Wishbone mounts (lollipops) can be changed easily without needing to remove the wishbone itself..
buy them in this format with the bracket if you want to replace with standard:
https://www.ebay.co.uk/itm/Wishbone...adster&hash=item362cf4c530:g:c7oAAOSwVkNanfAR
That is an example there are many types
Unless you want to polybush, then you can buy with a bracket, or cut the old ones out, and put the new poly bushes in.
