I am getting Inlet cam angle sensor code , My question is , is it possible that a poorly functioning vanos could be causing it, and if so maybe I should just wait until my vanos rebuild kit arrives. But I also have to consider that it much easier to get at with the vanos and actuator removed. What would you do,?..If the answer is, "replace it while your in there" and if so, OEM or aftermarket, and from whom is the best deal, ?.. Thanking you in advance...
