Induction kit for a 3.0
Adam1990
hi been browsing the web and the likes of Ebay for a while now can seem to pin down a decent kit for my 3.0 apart from a k & n cone type. Any some others just listing 2.8 and 3.2. Im after realy a closed filter or one in a housing to prevent heat soak. Any pointers in the right direction would be great, or anything on the 2nd hand market
Finding generic cone filters is fairly easy as long as you get the correct diameter on the pipes. As you say though, finding one with a decent heat shield is more tricky and tends to push them in the the £2-300 area. You might want to consider making your own heatshield if you have some basic skills. Make a template with card board and tape, and then use that to make it out of something more sturdy and reflective.
5harp3y
I'm building one right now but without the heatshield as I think it's not that important.
In testing I drove last night for an hour really giving it some (whole car was boiling) think full on redline driving
The stainless inlet I've built wasnt even hot to the touch.
When moving I don't think it's an issue tbh
Plus space is mega restricted in the z3 and you need as much filter as you can get which the heatshield would take up
The final thing is that none of these kits really add power, they just sound awesome. (I shall be demonstrating this on sunday)
Antm72
South Yorkshire
I went the Simota route as said new they are not cheap.
I brought a kit listed on ebay for and E46 330 ci and E36 ///M3 .
Wrong kit but my thinking was that it would obviously deliver the air and at worse i would have to mod the carbon surround to get it to seat right.
I had to trim it in the end but only on the underside to allow it to sit over the inner wing better but it was well worth the effort and although on the higher price side like most things it is a quality but of kit.
Made my own shield to start with the filter was still warm though but never had any issues with it giving lack of power because of it.
Adam1990
cheers im going look into that, thats part the issue i have knowing what bits off different cars fit or are close enough.
Adam1990
I think the question is, does the 2.8 stuff fit the 3.0 with minor tweaking? As i can find plenty of that
5harp3y
measure you maf, and then send me a picture of you're engine bay.
then i can tell you if my kit will fit :D
Antm72
South Yorkshire
It difference was that the 2.8 has a smaller maf than a 330/ M3 so i had to reduce the size of the out let from if i remember 90mm to 80mm so in your case the 2.8 item may reduce air flow as you would have to up its size rather than in my case lower it :thumbsup:
5harp3y
Yeah so your maf is 90mm so 10mm bigger than the 2.8
isnt tricky to make one but its just time consuming measuring up to get a big enough filter in theer to cope with the CFM needed
My kit wouldn't fit right now but its good info for the future. i might make one up!
