For Sale Indicator Relay - LED Modified
ZEDonist UK
Cambridge, United Kingdom
3.0 Roadster
Hi Everyone,
I am selling modified original OEM indicator relays which stops hyperflash when using LED indicator bulbs.
I have tried a significant number of LED bulbs, all promising no hyperflash, yet after 15 minutes they all end up hyperflashing without this relay.
Orignal BMW part customised.
2 minute install - plug and play.
You can use any LED bulb of your choice and the relay will function correctly
LEDs have a much higher light output.
Load resistors and wiring alterations are not required.
With LEDs you won’t see an orange reflection in your clear indicator lenses when not in use.
Partial refund when you return your original relay
Having spent a long time finding a quality bulb I have bought a small batch and put together a kit for anyone who wants a one stop shop.
These bulbs are, in my opinion, some of the best available and significantly less expensive than places like LEDperf.
The bulbs:
Brushed aluminium body - no degrading plastic housing!
84 SMD LED and 24 SMD LED
800 lumens output per main corner bulb
LEDs cover the whole bulb. No dark spots.
I am selling the relays and bulbs through eBay and my website.
www.ZEDonist.com
The website is cheaper as eBay commission is significant!
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
Hi Martin. Would the modified relay still work with standard bulbs installed?
ZEDonist UK
3.0 Roadster
Good morning,
Yes, it will work with all filament (standard) bulbs or any combination of standard and LED if you wanted / needed to mix and match.
It will also work with any existing LED bulbs you have.
