Immobiliser?
rmoconnor41
The vehicle has developed an issue since the battery was removed and charged after several months of not being driven.
The vehicle will start but won’t run
Is this likely to be related to the battery removal or immobiliser?
Thanks
Oddly Godly
dunstable
z3 2.8
If it starts I would think that rules out the immobiliser. Have you access to a code reader. You say it starts, does it tick over?
Fuel pump likely culprit.
Sounds like the Maf has failed if it runs with it disconnected as it runs on default settings, you could try cleaning it with Maf spray cleaner and then plug in a code reader that can display live data and take a look at what the Maf is doing with the engine running. If you replace it only use oem brands like Bosch or Seimens do not use cheap ebay Maf's they don't work, been there and ended up going oem, got a refund on the cheap one thankfully. Same for all other sensors like camshaft and crank sensors always go oem, have had success with HASS brand camshaft sensors in the past so that is a cheaper option that works. Sophers BMW in Lincoln are a good source of spares as they give Forum members a discount but you have to ask for it, they post items out to you so just a phone call required. Use Realoem website to look up part numbers, enter the last 7 letters and digits of your Vin number and it will bring back details of all parts fitted to your car when it left the factory.
