Iffy passenger door opening
137699
Hampshire
M Coupe 3.2 S50
Strange one here & wonder if anyone else has had this - a cursory search didn't yield any results...
The exterior passenger door handle on my zed has become a bit erratic. After being left for a few hours it doesn't want to open from the outside. You pull the handle and it pulls up quite a way before hitting a resistance but it doesn't unlatch the door.
If I then open the door using the interior handle the door will now open and close correctly and the outer handle works fine.
Leave it a few hours, and it stops working again....
Any ideas?
AntStark
Hampshire
2002 3.0 Sport
Mine did that..cured with some spray lithium grease in to the latch
