Tom Holland
- Joined
- Jun 28, 2017
- Points
- 49
Good evening all, I recently bought a Z3. With a failed yaw sencor and leaking hardtop roof. Since owning the car I have tried to fix the leak but suspect its not only the join at windscreen. So todat I thought I would locate this yaw sencor. Now for those of you that now about these things your probably saying "No! Wait read up a little 1st!"
So to just to the chase.Door trims off, seats unplugged and removed. Fond the yaw sencor and it looked OK. What didn't look OK were the Temic mrsA3-wpairbag thingamejig. So I unplugged them. This was because under both sides the carpets are sodden! So now I've started to remove the centre consol but can't get it out. It feels secured at the point behind the casset /radio player. So on with getting call the rear plastic away. So hard top off,Ignition on softop closes on the button, roll bar loops out, central luggage storage out. Then at this point it all turned to poo!!!! Because I switched on the ignition to operate the softop again and the ignition just went "click" Have I killed my car?
