mccalli
- Joined
- Mar 18, 2018
- Points
- 18
How do you re-attach the regulator guide rails to the glass on the window?
Context:
1998 Z3. Am trying to fix the driver's side window, which didn't wind at all. Have taken apart the front door panel, seen that both clips had come out of the guide rails on the window, and that one guide rail was lying on the floor at the bottom of the door.
Hmm.
Have replaced with two new clips, slotted those clips into the guide rails. To do so I had to remove the rails from the glass - simply couldn't line them up any other way. Neither appeared to be fixed on - one had already fallen off (the longer one) and the smaller one at the front just slid off with no real effort as well.
The problem is that I can't get them back on the glass. I mean, I can but they don't stay there for very long. A few winds later and it's all come off the window again. Is there a trick I'm missing? Are they supposed to be glued or something?
All help appreciated - car is in bits right now. Thanks.
Context:
Hmm.
