How To Clean and Polish Your Plastic Headlights
si-forks
worcester
I've done this on my 525 and it works well but i used T-cut and a polishing mop
Si-forks on tapatalk
Boysie
West Chiltington, West Sussex
M Roadster S50
Is a polishing mop necessary, can this be done by hand and a bit of elbow grease
Are there marking on the cover?
si-forks
worcester
Give it a go on a corner see how you get on
r37
did mine with some t-cut and an old rag, came up a treat. My dads 206 lights were very bad so i did them with some wet 1200 grit then followed with t-cut. Both cars looked factory fresh.
Boysie
M Roadster S50
r37 said:
My dads 206 lights were very bad so i did them with some wet 1200 grit.
Your a brave boy :-s
si-forks
worcester
Nice one i will try wet' n 'dry next time good tip
r37
they really were bad: yellowed, covered in stone chips, rough to touch. The 1200 grit took them back to a light haze and the t-cut bought them up lovely. Alot of the kits you buy for headlight restoration come with a small piece of 1000 grit so using some wet 1200 was fine. It barely leaves a mark on clear-coat so the hard plastic of a headlamp would recover fine.
Jamezee
Peak District
Z3 2.2 sport, Z4 Coupe 3.0Si, E38 728i Oxford green and beige interior
Megs do a headlight restoration kit now, i bought one but just not got round to doing it. The guy at my garage is going to have a do with it when zeddy goes in next. :)
