- Joined
- Dec 8, 2011
- Points
- 165
My wipers on the kitcar only work as if the car is stationary.
Intermittent wipe only.
The instrument cluster has been removed and replaced with other instruments. The speedo signal wire (SW/WS) (Black / White) is disconnected.
My first thought was that if I supplied this wire with 12v, or shorted it to earth, the speed reactive stuff would react. So I tested the wire on my blue car (standard M Roadster). The wire is 0.31v when everything is switched off, 11.28v when the ignition is on, but engine off, and seems to follow the alternator, but with a reduced voltage when the engine is on. The voltage is not any different when the car is in gear and the speedo thinks the car is moving.
To test the wire, I disconnected the driveshafts and ran the car in gear.
The wipers change from intermittent to normal speed at around 5mph. The voltage on the SW/WS wire makes not significant jumps or variations.
My conclusion is that this wire is a CANBUS-type signal wire, and can't be fooled in the normal electrical ways.
Does anyone have any ideas how I can make my wipers behave normally?
One option is to bypass the complete Wash/Wipe module, but I don't really want to do that.
