Copied from the MOT Testers manual. Which is free on line to view , copy or Print.
0. Identification of the vehicle
Registration plate (number plate) and vehicle identification number rules and inspection for car and passenger vehicle MOT tests.
Show all sections
0.1. Registration plates,Showthis section
0.2. Vehicle identification number (VIN),Hidethis section
You must check the vehicle is displaying a legible vehicle identification number.
A vehicle identification number (VIN or chassis number) is required on:
- kit cars and amateur built vehicles first used on or after 1 September 2001
- all other vehicles first used on or after 1 August 1980
Vehicles may have the VIN displayed in more than one location, but only one VIN is required to be complete and legible.
Check that a vehicle does not have more than one VIN displayed, other than for multi-stage build vehicles. Multi-stage build vehicles can have 2 VINs, both of which may have the same last 8 digits.
When registering a multi-stage build vehicle for test, enter the last 6 digits of either VIN, along with the registration number. If the MOT testing service finds a match against either full VIN this should be accepted.
If you do not find a match in the MOT testing service, create a new vehicle record using the converter’s VIN. A converter’s serial number is not a VIN.
Defect | Category |
(a) VIN missing or cannot be found | Major |
(b) VIN incomplete, illegible or obviously falsified | Major |
(c) More than one different VIN displayed | Major |
