Hood Switch
Chris Hunter
Has anyone moved their hood operating switch from the rear to the front? Is it simple or a PITA. any info gratefully received. I am about to move mine.
thanks Chris
You may find some help here Chris,
or here,
View: https://www.youtube.com/watch?v=zRIn2Xn3d5M
Chris Hunter
Hi Tony took a deep breath and bit the bullet. Nowhere as difficult as I feared. Both seats out, tunnel cover removed, all switches etc clearly marked hood switch wiring untied from harness for half its length then folded forward. DSC switch cut and a length of light 5 core soldered in its place and the switch reattached for fitting in place of the hood switch. Probably 6 hours.thanks Chris
Chris Hunter
Further to my Hood switch relocation, I fell for the 5 card trick. I switched on the ignition to test check my wiring, and of course lit up the airbag lamp.
any ideas on the best resetting tool. It is a 2000 3.0i.
Thanks in anticipation
Chris
